1938 Fleetwood Voltage Regulator
Started by jcostello49, July 23, 2013, 04:24:24 PM
jcostello49
Hello, I am seeking a 6 volt voltage regulator for my 1938 Fleetwood Cadillac.  I would appreciate your help finding this.  Thank you, Jere Costello  (310) 740-1602    jcostello@cleanstreet.com
cadillac60
Jere,
I purchased a correct voltage regulator from Yesteryear Antique Auto parts. The model no. was a 1118204 6 volt positive grnd 3 wire reg.  I purchased it in 03 & is still functioning properly.
I would think yours would be the same as my 60 special V8
Bruce W
Bruce Watson
Brad Ipsen CLC #737
If by Fleetwood you mean a series 75 or 90 these have a very hard to find 6 terminal VR and even harder after you find it to get it to work.  If you are just after function a standard 6 volt VR available at auto parts stores will work if you hook the Bat, Gen Arm, and field up.  You will lose the starter interlock on run.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
jcostello49
Cadillac60,
Thank you.  I contacted Yesteryear and they were very helpful.
Brad Ispen CLC #737,
Thank you for the information, it was very helpful.
cadillac60
Jere,
Glad to hear that yesteryear were able to help you,
Bruce W
Bruce Watson
