1947 Convertible
Started by Jeff Trahan, July 31, 2013, 12:37:39 AM
Jeff Trahan
I am almost done stripping my '47 convertible to get ready for body work.  I still need to remove the three chrome studs that hold the front of the convertible top above the windshield.  The set screws came out but the studs still won't budge.  Is there something else I need to do or are they just rusted on?  Thanks.
Jeff Trahan
Jeff Trahan
#28564
1938 Cadillac V16 9033
1947 Cadillac 62 Convertible Coupe
1958 Cadillac Biarritz
Terry Wenger
If I remember correctly, now you unscrew them.
Terry Wenger
Terry Wenger CLC #1800
tewv16@sbcglobal.net
1932 355B TSD
1939 7557
1940 60S
1941 60S
1947 6267 Conv.
1949 6207X Coupe
1963 60S
Jeff Trahan
Thank you Terry.  You are correct!
Jeff Trahan
#28564
Bill Ingler #7799
A word of caution. When you screw the 3 pins back to the windshield header, make sure that all 3 pins are at the same height and aligned to accept the latching rods. If you are using new rubber weatherstripping you might find that with the new weatherstripping and if the pins are not at the same height/aligned, when you try to close the handle, the latching rods will not move through the holes in the pins. The original chrome latching handle is a pot metal casting and not a steel stamping so if you continue to force the handle to the closed position, the handle could break. When I bought my 47 the handle was broken and I was fortunate to find someone who was selling handles that had been cast in brass.
