suggestions wanted for interior water stains
Started by Cooke, August 12, 2013, 07:29:33 PM
Cooke
I have some water staining on my 38, 60S on the door panels, not horrible but noticeable. I have had no success in cleaning them. Any ideas as how to get rid of them or a dye product that would work well?? The interior otherwise is very nice. Thanks Martin
Ronnie
I use a mixture of household amonia, rubbing alcohol, and water. I use a gallon of amonia, a pint of alcohol, and mix with matching amount of water. Wet the entire area or panel evenly using a sponge. Let air dry and sometimes it takes a second application.  This solution will not hurt fabric.
Ronnie Hux  CLC#22548
1974 Eldorado ELC
2009 CTS 3.6 AWD
Barry M Wheeler #2189
Hi Ronnie, Was that a pint, or gallon of water? Or a gallon and a pint of water? I want to try this on my own 60S.
Barry M. Wheeler #2189
1981 Cadillac Seville
1991 Cadillac Seville
Gene Beaird
The way I read it:
1 gallon ammonia
1 pint alcohol (isopropyl, methyl or ethyl, or other?)
1 gallon +1 pint of water.
But I may be wrong.
Gene Beaird,
1968 Calais
1979 Seville
Pearland, Texas
CLC Member No. 29873
