1976 Eldorado with a ruff idle.....
Started by flw004, August 12, 2013, 07:46:24 PM
flw004
Fellows, I need some help.....My 1976 Eldo was running great until I had a A/C controller replaced.  It doesn't seem that the two are connected but it's all I have to work with.  The car now has a ruff idle.  Otherwise it runs just fine.
What I've done so far is replace the plugs and wires, check the timing and idle speed.  All the vacuum hoses appear to be fine.  I appreciate any advice you may have........
n2caddies
I suspect a vacuum leak somewhere. Check with your device manual schematic and make sure everything us where it should be. You may be able to hear a leak in the dash as you turn on the AC controls. Check all the fittings on the carb and distributor advance.
Randy
Randy George CLC# 26143
1959 Series 62 Convertible
1960 Series 62 Convertible
1964 Deville Convertible
2015 SRX
flw004
Aside from those suggestions be aware that the rear compressor bracket bolts to the intake manifold, and if the bolts are not in, tight, un-stripped and sealed, you can get a vacuum leak at those points.
Greg
Does a 76 have a fast idle circuit that engages with the AC?   Perhaps changing the controller changed how that solenoid operates?   Maybe before it was stuck on but the repair got it off or stuck off?
TJ,
They quit putting an "AC Idle speed step up" on the cars stareting, I believe, in 1969 with the 472/500/Quadrajet.
Greg
100% correct, 1968 was last year of the vacuum fast idle speed up when a/c is energized.  Vacuum leak is most likely source of fast idle.
