59 Cadillac with AC Fan Belt Order
Started by Jeff Wilk, August 31, 2013, 07:37:44 AM
Jeff Wilk
From front of car to back of car ..... Which fan belts go in which order on the 3 grooved pulley?  Best clearance for lower radiator hose has it as follows:
Front........ Power Steering Belt
Middle........Air Conditioning Compressor Belt
Back..........Generator Belt
Southern New Jersey
SOLD
1958 Cadillac Sixty-Special
1958 Cadillac Sedan
1958 Cadillac Coupe Deville
Grant Owen
Jeff,  The belts only go in one order unless you have done something very wrong the order of belts Front A/C , Middle P/S , Back Gen . Get the correct Radiator hose.
Jeff Wilk
Thanks Grant!!  I see what you mean about only one way for the belts to go. Fixed them today and moved the hose a bit more. Good clearance now compared to what was there before.
Cleaned it all up for a third time now and ran the car at idle for 15 mins and NO leaks. Took it for three longer test drives faster each time and checked after each.....NO leaks!!!!!!
Southern New Jersey
SOLD
1958 Cadillac Sedan
