Idle Screw Location, and Fast Idle Solenoid Issues with AC
Started by Jeff Wilk, September 07, 2013, 11:59:14 PM
Jeff Wilk
On the '59 with Tri-power where is the Idle Screw and also the Fast Idle setting?  Our car is running again but the idle is a bit low.  I also have the AC working again but do not believe that the fast idle "kick-up" is working when we switch on the AC.  Any ideas on how to check/fix that?
Southern New Jersey
SOLD
1958 Cadillac Sixty-Special
1958 Cadillac Sedan
1958 Cadillac Coupe Deville
Idle screw is on ther cenetr carb linkage drivers side.  Flip the choke over, look at the linkage for the choke you will see that set screw also.
