1960 Hydramatic flywheel to crank spacer/bushing?
Started by paulkersey, September 10, 2013, 12:10:35 AM
paulkersey
Was looking at some old posts and I cant recall them now but there is a shop diagram of what looks like a brass spacer/bushing that rides between the flywheel and the crank to keep the ring gear from sliding forward?
This scared me. I do not recall ever seeing something like this during disassembly or around the garage.
Sorry I do not have the part number.
Getting ready to mate the trans to the 390. all 1960 stuff.
This is what I have going together.
J. Wicks # 19583
The spacer is a round disk, made out of tool steel, and is the outer diameter of the crankshaft spigot hole, and about 3/16" thick, with a small 1/16" hole in the centre.   I think a 1/4" thickness is too thick.
I was pulling the trans off, and out of the corner of my eye I had the feeling that something fell onto the ground.   Took a while to find it in the dirt, as I really didn't know what I was looking for
I don't have a picture of it, but I did manage to find it and figure out where it went.
I wouldn't be surprised that there are a lot of vehicles out there with this part missing, as one doesn't expect to see something like this that could fall out.
Grant Owen
Attached is a pic of the spacer you need, I machined a few of these a while ago but have used or sold them all, maybe time to machine a few more. The most likely cause of vibrations is a missing spacer if the trans or engine has been out.
paulkersey
Thanks guys. I am usually pretty careful with this kinda stuff.
That goes in the end of the crank with the small hole out?
J. Wicks # 19583
Doesn't matter which way, as the hole is just there or probably hooking a piece of wire into it to remove it from the end of the crankshaft if it ever becomes stuck.
I believe the spacer is there to act as a pre-loading mechanism when bolting the drive plate to the fluid drive.
I think that any time one of those transmissions was separated from an engine in a wrecking yard, the discs got lost.   If not then, more likely as the engine was being transported around the yard to the customer.
