1931 V 12 vacuum tank
Started by old car fan, September 19, 2013, 12:16:01 PM
old car fan
Could someone provide picture of a vacuum tank .Trying to find out what tank it used.Thanks
Chris Cummings
Tim,
If you go to this site:
http://gmheritagecenter.com/gm-heritage-archive/vehicle-information-kits.html
and click on the 1931 Cadillac V-12 link, the resulting .pdf has a picture in the Preliminary Service Information brochure.  If you have a shop manual, it has more detailed images.
The 1931 V-12 vacuum tank was a single unit that was internally separated to provide for the two carburetors that fed the engine.  By contrast, the V-16 had two separate vacuum tanks, one for each carburetor.  Stewart-Warner manufactured the units.
I hope that helps.
Chris Cummings
CLC #20072
old car fan
Chris,for some reason,when I click on the licence agreement,my cursor gets a yellow star,will not let me access the website?Also,the tanks that I have seen,it appears to be a standard tank,split for the carbs @fuel sediment bowl at the bottom of tank?Original?I have not seen any very good pics.Thanks for the info,i will keep trying.
Johan Boltendal #158
old car fan
