Cadillac Trunk lock
Started by Two Crabs, November 13, 2013, 08:56:40 PM
Two Crabs
Does anyone has a drawing or a picture of the trunk lock.
The Cadillac Emblem that flips up and give you access to the lock came off and it is not readily apparent how it reattaches.
(1973 Cadillac Eldorado Conv. )
Two Crabs
1973 Eldorado Convertible
cadillactim
It's held on by  a spring.  The spring probably rotted away, and that's why the emblem fell off.
Tim
Tim Groves
Two Crabs
There is no reference to it in the workshop manual.
Two Crabs
Two Crabs
On a second note I found a similar set up on a junk 75 that also had a broken spring and I saw how it works.
Does any have any sources for those springs or the mechanism ?
Two Crabs
