Question about 1938 door locks - Authenticity manual
Started by joeceretti, November 15, 2013, 02:49:23 PM
joeceretti
I noticed in the authenticity manual it says that, when exiting, the door locks must be locked by using a key from outside. Is this correct? I noticed when I got my car, if you lock from the inside and then close the door the lock unlocks. BUT if you lock from the inside and then when outside hold the handle down and close the door it stays locked. Has someone changed the latches in my car or is the manual incorrect? I can't see every latch being switched out, but I don't want to just assume.
Brad Ipsen CLC #737
Your locks are operating exactly as designed.  It may be better not to get in the habit of using hold the handle down method.  That is the way to lock the keys in the car.  I always make a point to use the key in the drivers door.  That also gives the opportunity to observe the clever design of how the cover on the lock cylinder stays open by itself.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
joeceretti
You just added another item to my list. My covers don't stay open. I also am missing the linkage from the cylinder to the lock. I haven't been able find a picture or diagram of how they are connected.
joeceretti
Thanks Art, on mine there is a key on both front doors.
Brad Ipsen CLC #737
Joe,
Checked the parts book and 38-60S lock is different than 39 to 41-60S.  I then assume the 38 does not have the hold open cover on the lock.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
This must be a difference with the 60S as my 1938 60  has the locks in the door handles same as 37.
joeceretti
Lots of little differences with the 38 60S, it's a one off Fisher Body, the other 38's and later years of 60S are Fleetwood bodied, as far as I know. It's made it a pain for the little fiddly parts. I am getting close though.
