56 coupe and 59 comercial chassis steering
Started by swiss, January 15, 2014, 02:52:41 AM
swiss
hello
one  question from my side, how can i get this horn wire out of the spindle? i dont want just to pull because i have fear i destroy something, is it bolted on?
im currently restore both columns for this cars
happy to get help
The wire is soldered to a ring. This can be seen through an aperture from the steering column tube.
A factory shaop manual would certainly help; they are easely available.
swiss
hello
thanks
i have the reapair manual for the cars, but in this its just described there is a spring you have to loose, but i didnt found the spring. its not verry good explained and not drawing or pic in it. have someone a drawing? or something like this?
Do you have this picture in the '56 shop manual? There should be no problem, they are so simple designed...
swiss
hallo roger
yes i have this, but i still can not see to where its connected, to the horn bushing? do i have to remove the hole spindle? snap ring , spring..... to get access?
or is it possible to get access with the column jacket?
rainer
Rainer, you have to remove the column jacket. Once this is removed, you will see a window or aperture large enough to unsolder/solder the wire. You may have a good look at the brass bushing: I had one which was cracked and I had to replace it. Don't ask how, it was 20 years ago...
