'76 Cadillac Speaker Question(s)
Started by Jeff Moffo, January 20, 2014, 08:09:28 AM
Jeff Moffo
Good Morning,
I recently had the car stereo (Delco) radio repaired in my '76 Cadillac.  It works fine now...problem is..no sound out of the rear speakers (none before repair either :o).  And the two, original 3.5 in speakers in the dash are working, but the passenger side vibrates and moans like crazy.  God forbid, the treble is turned down and bass turned up. :-\
My question would be...anyone know why the rear are not working?  I already pulled the connections and tried that.  Nothing.
And the other would be does anyone have a recommendation for replacing the front?  Sources besides Ebay?
Thanks and have a great day.
Jeff M
North Jersey
Best of all, it's a Cadillac....
'76 Coupe DeVille - Claret (Sold)
'73 Series 60 Fleetwood (Sold)
'76 Coupe DeVille-Dunbarton Green
Jeff Wilk
Go to Electro Tech. Website is.   Turnswitch.com
They will have answers and correct speakers for your car
Southern New Jersey
SOLD
1958 Cadillac Sixty-Special
1958 Cadillac Sedan
1958 Cadillac Coupe Deville
Jeff Moffo
I checked that site out...
I was just wondering if there were newer speakers with the same Ohm ratings as well.
I'll give them a call.
Jeff M
North Jersey
Any 8-10 ohm speaker that physically fits will work.  Many modern speakers are only 4 ohm and they will harm your radio.
8 ohm speakers in all sizes should be commonly available.
sjocad
I had the same problem,but after hours with looking,the rear-speakers where SHOT.
Try new ones...
svein sjoblom,CLC # 12214.
1937 Lasalle opera coupe series 50.
Aprules2
If you have free time, go to the junkyard and grab a pair of 6x9s out of like a 2003 malibu. I went to get my radio checked out to see if it needed a rebuild. He hooked a cheap speaker up to the leads in the back and it played. As it turned out earlier that week a customer had a sound system installed in his Malibu and they had a set of 6x9's from it. I bought them for $50 installed and I used them in my car for years, they actually sound pretty good too. Later I kept the factory radio and used line out converters, an equalizer, a 400 watt amp and at the time Audiobahn speakers were great so I used a set of them. The car sounded great.
Jeff Moffo
Trouble is the car radio is the original.  I just had it restored.  Newer speakers generally draw the wrong Ohms and will burn out the radio. 6x9's can still be found for this unit, so I am in the process of waiting for the correct ones.
Jeff M
North Jersey
Aprules2
I used the factory 2003 Chevy Malibu speakers with the factory 75 Caddy radio for almost 2 years daily with no problem. And theyre cheap, I think they were 10 or 8 ohm I can go out to the garage and check.
