All Cads
Author Topic: 1941 60 special gas line and filter  (Read 712 times)
Offline mr41cadillac
  • Name: j mclaughlin
« on: January 29, 2014, 06:40:53 AM »
any advice on the original gas line to fuel pump in engine compartment. was there a filter if so where also if not where can I put one and what kind.  I have previously taken off tank cleaned  and trteated with that par epoxy but I feel like I should have some kind of in line filter.  thanks john.
joeceretti
  • Guest
Re: 1941 60 special gas line and filter
« Reply #1 on: January 29, 2014, 07:13:10 AM »
 Normally the fuel pump would have had a glass bowl sediment filter.  This type alone is not sufficient,  It will allow some small particles into the carb.  Ideally for maximum protection of your carb you should have a 100 micron  filter before the fuel pump and a 40 micron filter after the pump. I  do not think many people  do it this way, for whatever reasons but at the very least you should add a filter before the fuel pump.
Offline Bill Ingler #7799
« Reply #2 on: January 29, 2014, 08:05:40 AM »
Hi John: Most all who drive flat head Cadillac install an auxiliary electric fuel pump to help eliminate vapor lock as well as to fill the line and carb before starting. The usual place to install this pump is in the rear near and above the tank so I put a filter in the line between the tank and the auxiliary pump. I use the type of filter pictured below which you can see when it needs to be changed. The filter is screwed together and comes apart easily to change the filter element. These filters are available at NAPA.   Bill
All Cads
