39 Lasalle serial/vin #
Started by 39lasalle, February 02, 2014, 08:49:53 AM
39lasalle
I recently came into possession of a Series 5019 Lasalle on a bill of sale. I don't know too much about them but I am trying to find the serial #.
Any help would be appreciated.
39
Serial number is the engine number and its located behind number 7 cylinder on the bell housing, sometimes hard to see.  A similar number is found on the chassis rail just behind the steering box on top the frame usually with the first digits different.
39lasalle
So far I only see a three digit number upside down behind cyl. No. 7. It looks like 128 and they are about 3/4 inches tall.
I can't find anything on the frame rail, yet.
39
C.R. Patton II
Hello K. Smith
Glad to read of your acquisition.
If you stand adjacent to the left front tire with the hood up, look door at the chassis with a flashlight for illumination, the vehicle identification is stamped. If unclear use a wire brush to clear the residue then apply white chalk to enhance the numerals. The 1939 LaSalle range is 2290001-2313002.
On the firewall you will see a body plate. If you provide the information I will decode it for you.
I hope you retain the LaSalle, join our national/region near your residence.
All good men own a Cadillac but great gentlemen drive a LaSalle. That is the consequence of success.
joeceretti
The serial number on both the frame and the engine can be very difficult to read but they are there. Keep scraping, brushing or whatever method you choose and you will find them.
It is common and correct to have the vehicle registered under the number stamped on the engine. However in some areas the car will be registered by the number on the frame. Incorrect, yes, but it's the way it is some of the time.
39lasalle
Body tag
Style 39-5019
Body 8793
Trim 31
Paint 53
39lasalle
C.R. Patton II
Hello
1939 LaSalle 5019. 5 passenger 4-door Touring Sedan with 15,683 produced
Body 8,793. (Estimated date of manufacture Jan-Feb 1939)
Trim 31 is Tan
Paint 53 is Cavern Green which is unique
I am a fan not an expert. Allied Vaughn can provide actual data.
39lasalle
So what is the best way to get a title for this as I more or less inherited the car with no paperwork?
39
Tom Boehm
Hello K. Smith, I have a 1940 Lasalle and I did not get a title with it either. I live in Indiana. I asked how to get a title at the local office of the Indiana Department of Motor Vehicles. They told me I had to get a judge in the county I live in to issue a court order to the DMV to issue a title. I did it and it was not that big of a deal. So, ask at the department of motor vehicles in the state you live in how to get a title. Enjoy your Lasalle and post a picture!
Jim Stamper
     A bill of sale and an eyes on Vin #verification by a New Hampshire police officer and the little form he fills out is what it takes here.
              Jim Stamper CLC#13470
Bob Hoffmann CLC#96
Quote from: 39lasalle on February 02, 2014, 12:45:05 PM
Thanks guys
Found it, 2302610
39
Is that the FRAME #? Make sure it is & you title the car by that frame #. The motor had the same # when new, but motors can be changed. Using a incorrect motor # can cause LOTS of problems as some on the board can attest to.
HTH, Bob
39lasalle
Yes that is the number on the frame.  I took a Rolodex pad and my grinder to the frame and ground down to bare metal
39
39lasalle
Quote from: C.R. Patton II on February 02, 2014, 12:56:46 PM
Hello
Trim 31 is Tan
Car is black and does not look repainted and the Interior is blue and doubt that has been changed either,
thanks though   will investigate further
39
Alan Harris CLC#1513
No interiors on 1939 closed cars were originally blue. The only choices were gray or tan. Cavern Green was a very dark green and would have looked good with tan.
