water pump clearance 41 60 special manual shiet
Started by mr41cadillac, February 17, 2014, 07:04:53 PM
mr41cadillac
does anyone know the clearance between the impeller and the body on a 41 60 special? the rebuild kit gives no clearance spec nor does the shop manual thanks john
John,
Not so. Check page 47, Engine Specifications, it clearly shows under WATER PUMP the clearance.
jw
John Washburn
CLC #1067
1937 LaSalle Coupe
1949 62 Series 4 Door
1949 60 Special Fleetwood
1953 Coupe DeVille
1956 Coupe DeVille
mr41cadillac
thanks john would you have that figure handy as my manual is at the shop. thanks john
