1993 Allante Strong fuel odor
Started by Coupe, February 18, 2014, 02:08:30 PM
Coupe
After driving our '93 Allante for about 15 miles or more a strong fuel odor starts building in the cab. I am sure it's not coming from the engine compartment. Outside the car the strongest smell comes from near the fuel door. When you open the filler cap there seems to be more pressure than normal. Could this be a problem with the vapor canister or the tank vent valve?
Any thoughts/comments are appreciated.
1957 Coupe de Ville
1993 Allante
1949 Jeepster VJ-2
I'd suggest calling Dick Hussey in Florida.  He owns an Allante only repair and parts facility.
His number is 1-561-844-3938.
Another Allante expert is Johnny Monzo in NJ.  1-609-634-6518.
The other is Tom Rhoner at www.allantestore.com in CA.
Tom Rohner
trohner@san.rr.com
619-807-8770
Good Luck,
Coupe
Thanks Brian for jogging my memory regarding Dick Hussey. I called him and he suggested it may be the gas cap not sealing properly. His fix is to inspect the o-ring in the cap and if not cracked use some silicon lube on the o-ring. If that doesn't fix it try a new cap.
Dick is valuable source for Allante owners. He has helped me in the past with parts and advice. He shared his knowledge freely on two occasions. One when I had a hard time bleeding the air out of the cooling system and another when I was swapping out a failed window regulator. The shop manual's directions were not the way to go on the regulator and Dick's were spot on.
1957 Coupe de Ville
1993 Allante
1949 Jeepster VJ-2
Alan Harris CLC#1513
I had a similar problem with my 1987 Allante years ago. Replacing the cap solved the problem. They are cheap and readily available.
I think I bought one at Pep Boys. The cheapest fix I ever had on that miserable money pit.
D.Yaros
Quote from: Alan Harris CLC#1513 on February 18, 2014, 09:04:41 PM
Is it safe to assume you are not a huge fan of the Allante?   ;D
Dave Yaros
CLC #25195
55 Coupe de Ville
92 Allante
62 Olds
Coupe
When the new gas cap finally came in it took care of the problem.
1957 Coupe de Ville
1993 Allante
1949 Jeepster VJ-2
Dan LeBlanc
Excellent. Glad it was a simple fix
Dan LeBlanc
