Thanks Gavin. I found one today but it wasn't anymore helpful. Since my last post I have done a little more work. This a pic looking down into the distributor hole with the cam on the left and the oil pump shaft at the top. I think that hole in the center is a drain back hole and the one on the bottom right is the hole that gushes oil when I spin the pump. Does anyone know if that hole is suppose to be plugged or does something connect to it?
