correct hubcap centers for 1959 sedan deville
Started by MY 59, March 21, 2014, 06:48:26 AM
MY 59
Hi all, after your knowledge again!!
I have just noticed the 4 hubcaps on my '59 sedan deville have 1 odd center cap.
I have purchased another complete set of 4 and they have the same mix of 2 different types.
both styles are white, with 1 being a little more ornate than the other
can throw up a comparison pic in the morning if need be, but figure you guys know these ald babies inside out :)
perhaps the more ornate is eldorado? or the less ornate the base model..and I have ended up with a mix
thanks for your help as always :)
David Bone :)
1959 Cadillac Sedan Deville
1967 (aussie) ZA ford Fairlane
This is an Eldo cap with a correct center if that help.
MY 59
Thanks Brian, definately not an eldo center then :)
here is a pic showing 3 of 1 kind and 1 of the other.
the 4 remaining on the car have the same mix??
I only really care about the front wheels, as the rears arent really seen, just want to know which one is for a sedan deville?
David Bone :)
Post a pic of the whole cap.
Those centers are not for a regular 59 cap.
Not sure you have the correct caps at all.
Jon S
The lower left is correct. The others are reproductions
Jon
1958 Cadillac Sedan De Ville
1981 Corvette
2004 Mustang GT
MY 59
thanks Jon & Brian,
here is my driver's side wheel, and cap from passanger side
drivers side has the lower left emblem
David Bone :)
I defer to the 59 guys here.
I am not as familiar as I am with the Eldo/Fleetwood caps.
Here is a link to McVey's repro stuff:
MY 59
definately lower LH emblem, with more detail to white squares and arched section
problem solved! thanks guys
David Bone :)
