41 60 Special and radial Tires
Started by Eric Voigt, April 04, 2014, 09:49:30 AM
Eric Voigt
Finally have decided on putting radials on and not sure what size will work with the skirts.
I would like the 235/75R's however, Coker is claiming the 215/75R is a better fit.  Also, thinking of adding the repro Eldo wires,  I've seen a few with them and think they really set the car off.
Eric Voigt
1941 Cad 60 Special
1947 Cad 7533 Derham Limo
1963 Avanti Supercharged R2
1966 Olds Toronado, Deluxe
1969 Dodge Charger
1971 Olds 442 Conv
Jon S
Coker is probably correct.  Radials are a bit wider than bias ply's.  A 235 75 15 fits very tight in my spare tire wheel well whereas the original 8:20's slid right in.  What is the original size tire your car calls for per your manual?  I doubt it was an 8:20.
Jon
1958 Cadillac Sedan De Ville
1981 Corvette
2004 Mustang GT
I ran 225-75R15s on my '41 60 Special when I had it back in the '80s.  The wires will look nice, not original to the car of course.  You will find them a royal pain to keep clean, fortunately I have a lift and can put my '35 Caddy wheels at about chest height and it makes the job easier, but still a time-consuming pain.
Barry M Wheeler #2189
Barry M. Wheeler #2189
1981 Cadillac Seville
1991 Cadillac Seville
Jon S
If original size was 700 x 15, then the 215 x 15 Radial is the max you would want to go.  The 235 x 15 replaces the much larger 820 X 15 and the 900 x 15 used on Lincolns.
Jon
1981 Corvette
2004 Mustang GT
Bill Ingler #7799
You need to be careful in buying a radial so the width of the radial tire when mounted will allow clearance of the fender skirts. This is critical especially when buying radials for the 42-47 62 series. That is the main reason I bought the R700X15 from Diamondback. I believe they said their R700X15 radial has only 1/8 inch wider width profile than the original 700x15 bias ply tire that was original to the car. I used the same Diamondback R700X15 radial (pictured below)on my 41-60 special and had no clearance problems with the skirts.   Bill
Dan LeBlanc
What about the new bias look radials by Coker that are now available?  I haven't checked sizes but they may have something.
Dan LeBlanc
Virgil Perkins
I have a set of Cokers on my '41 60 Special, 215/75 R15, have had them 9 years, look good, ride good, less than 1/2" clearance with the fender skirts. You won't be able to go much wider and clear the skirts. Good advice from Coker.
Virgil Perkins
