1977 Eldorado fusebox(s) location(s)
Started by fgexpert, April 10, 2014, 10:19:31 AM
fgexpert
Where is the fuse for the power windows on my 1977 Eldordo located?
Eric DeVirgilis CLC# 8621
Fuse block mounted on firewall to the left of steering column.
Power window circuit is protected by breaker I believe.
eldorado_boyblue
Yes, the power windows go through one of the metal circuit breakers in the fusebox, as do the power locks, trunk, and a few other things.
Daniel
1978 Eldorado
I don't remember about 77 but for sure by 78 the other car models had changed to the plastic blade type fuses so you have to be sure you are looking at a diagram for an Eldorado.   I'm guessing since they knew the Eldo was getting a major redesign for 79 they just didn't bother updating its fuse block so they still had the glass fuses.
1977 downsized models got the newer type fuses.
I believe Eldorado & Seville retained the older style fuses until their respective restyles in 1979 & 1980.
Makes sense about the Seville being 'old style' too.
I just remember running into the issue of looking at the wrong diagram when I was working on a 78.  It was really annoying because things just didn't quite match.    I was used to the earlier stuff where there was pretty much just one diagram for all the cars.
