1960 Cadillac Transmission... HELP!
Started by CaddyGirl, April 15, 2014, 03:31:55 AM
CaddyGirl
So I was driving my 60 limo today and it was doing perfect then all of the sudden it stopped shifting couldn't get it out of first gear.. So I parked it and had it towed home... I changed the fluid in the transmission a few weeks prior I drained the old fluid and sealed the tranny pan with a new gasket then obviously added new fluid. What does this mean? Thanks for the opinions in advance!! PS I've changed fluid this very same way in MANY other 60's that I've owned and I've NEVER had this happen!
Caddy Girl
S. Erickson
The CaddyGirl
Julien Abrahams
Check the obvious things first: is there plenty of fluid in the transmission? Is the fluid burnt? I am not sure whether this transmission uses vacuum and/or a governor to modulate the shift points. Check if your gear lever matches up with the setting of the manual valve connection at the transmission (I presume that you haven't disconnected this). Could be the governor that has failed some how. I don't know your knowledge about auto transmissions so forgive me if I make an obvious comment, but the governor governs drive axle speed related pressure in the transmission which via lines and other valves, makes the transmission shift into second and third gear when the drive axle speed (and thus the car speed) increases.
1954 Cadillac series 62
1969 Austin Healey Sprite
1979 Opel Kadett
I had once that Problem on my '56 de Ville, which had almost the same transmission. The trouble came from the governor.
C.R. Patton II
Hello Caddy Girl
I concur the culprit is the governor.
All good men own a Cadillac but great gentlemen drive a LaSalle. That is the consequence of success.
Walter Youshock
I had the same thing happen with my '57.  It wasn't the governor--it was the front sprag.  IF it's the gov, you're lucky.  Otherwise, you're looking at a rebuild.
Scenario was I got to a stop sign, hit the gas and the car wouldn't move.  Downshifted to 1st and was able to nurse the car home.  Went to the oldest trans shop in the area and the first thing he said was:  "the front sprag is shot.  It's gotta come out."
Maybe you'll have better luck than I did!
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
curly
I had a similar problem as well with my 59, the front fluid coupling (internal) broke a snap ring and the coupling came apart.  Mine was making a tapping sound similar to a lifter noise, it was the snap ring touching the rotating trans parts.
I'd check the governor first, it is inside the extension housing in the rear of the trans and can be accessed without removing the trans.  A lift will make the job much easier.
T Lewis
Dan LeBlanc
Try this.  It's worked for others
In reverse, get to 15-20mph and then shift into low.  She's going to chirp and make noise and liklely stall the car, however, if something is stuck, it will free it up.
Not saying it's a permanent fix, but others have done this and driven their cars successfully for years afterwards.
Dan LeBlanc
My suggestion was one among many, as described by other participants. You dont tell how many million miles have been accumulated, if the transmission has been rebuilt some time ago, etc...
I have rebuilt about 20 Hydramatic from this generation with all kind of damages...
CaddyGirl
Thanks for all your opinions and knowledge!! I know the fluid is full and not burnt! I just serviced the tranny about a month ago and put all new fluid in it ( Dex/Merc) and also a new tranny pan gasket. I've serviced many many of these 60 cad transmissions on other cars I've had and have never had any issues.. And this trans has never been taken out or rebuilt this limo has 67,560 ORIGINAL miles! I have receipts from the past owner and there's no trans work and the car is still a baby with really low miles so I don't see how it can need a rebuild....
S. Erickson
The CaddyGirl
Jon S
Quote from: Dan LeBlanc on April 15, 2014, 10:53:37 AM
Dan - I would think this would snap the motor mounts or do some other significant damage???  Can't be good for the driveline, universals, etc.
Jon
1958 Cadillac Sedan De Ville
1981 Corvette
2004 Mustang GT
Dan LeBlanc
Quote from: Jon S on April 15, 2014, 03:08:08 PM
Not saying it's fantastic for it, nor is it a permanent fix.  Just relaying what others have done.
YMMV
Dan LeBlanc
Happened to me once, I wound the car up until FINALLY it shifted.  Must have
been a sticky governor, never did it again.  Bruce Roe
dplotkin
Quote from: Caddy Girl Garage on April 15, 2014, 03:03:07 PM
the car is still a baby with really low miles so I don't see how it can need a rebuild....S. Erickson
Here's how, a 54 year old Hydramatic, regardless of its mileage is nevertheless 54 years old. The so-called spaghetti seals (big O rings and front coupling cover seals) get very hard at this age and don't seal. Eventually they hemorrhage internally to the extent that insufficient hydraulic pressure exists to apply clutches and bands. Unfortunately it involves coming out and going through. I did this for the same reason with my original 56.
Dan
60 Buick Electra six window
60 Chrysler 300 F Coupe
62 Pontiac Bonneville Vista
63 Chevy Impala convertable
63 Ford Galaxie XL fastback
65 Corvette convertable 396
68 Chrysler New Yorker
Glen
The 1961 Cadillac Shop manual says the only thing that will cause the tranny to run only in first gear is a problem with the governor.
Governor valve restricted
Governor weight missing
Governor No. 4 ring broken
G1 passage from governor to shift valve obstructed but this only happens after certain major internal work.
Glen Houlton CLC #727
CLCMRC benefactor #104
As somebody else wrote, the rubber seals are now hard like glass; they cannot do the job they are intended to do. I'm afraid, this is the time for an overhaul!
dplotkin
Quote from: Glen on April 16, 2014, 02:57:46 AM
Yes, but the shop manual assumes one is working on a 1 to 15 year old car, not a 54 year old car. The manual's authors never had to consider rubber seals turning to glass. I believe in first gear the front coupling is empty, fills to create second. and if it isn't holding fluid, it will not shift out of first.
Dan
Jon S
All of our cars are different, but when I decided to have my all original 1958 transmission re-sealed 8 yearsago, the mechanic went out of his way to inform me the internal seals were as soft and pliable as new and was extremely impressed.  I hope the replacement seals last as long!
Jon
1981 Corvette
2004 Mustang GT
txturbo
If the rubber parts are that hard it wouldn't even have first gear. You can out some TransX in it to soften up the rubber parts. Most likely it's a stuck governor.
D. Roden
1956 Coupe De Ville PINK
1963 Cadillac Sedan De Ville
Lucas transmission treatment is also very good.
I'd try a pour in remedy before yanking the Trans out.
CaddyGirl
Can you take the governor out without removing the tranny??? And where is the the governor ?
The CaddyGirl
