1958 Cadillac Fuel Pump Installation
Started by Jon S, May 06, 2014, 11:18:11 AM
Jon S
It's been a while since I last installed one and don't want to make any mistakes.  I know there is a push rod the pump rides against, but don't remember how the pump rocker arm interfaces with the push rod.  Does it ride on top as the 1957 Shop Manual implies?  The 1958 Supplement does not address the topic.  Also it says to lubricate the end of the push rod with engine oil.  I thought the engine oil pressure lubricates this location, but have read elsewhere it only receives oil when oil is added via the filler cap.  Responses appreciated.
Jon
1958 Cadillac Sedan De Ville
1981 Corvette
2004 Mustang GT
Jon S
Jon
1981 Corvette
2004 Mustang GT
Mike Baillargeon #15848
Jon,
I just did my 55 Eldo last weekend.
The lever sticking out of the fuel pump rides on top of the lever inside that fuel pump rod housing.
The rod rides up and down on the cam shaft inside the motor making your pump pump.
Sure add a little oil or grease to the place where the rod and the lever touch. It can't hurt.
Don't forget the gasket between the pump and the housing, I used a little film of permatex where the two meet.
Baillargeon
#15848
Jon S
Thanks Mike!  Any resistance putting it in if push rod is at lowest point?
Jon
1981 Corvette
2004 Mustang GT
All the fuel pumps I have put into my 50's Cadillacs over the years never had any real resistance, because the rod doesn't really move up and down a great deal.
It moves just enough to pump that lever on the pump.
So, just get the lever on top of the rod and then put the 2 bolts in and you'll be in good shape.
Baillargeon
#15848
Dan LeBlanc
I just did my 61 two weeks ago.  Seriously, from start to finish took 15 minutes.  I set the arm on top of the rod, had the bolts protruding enough to hold the gasket, pushed down slightly on the pump to line up the bolts with the holes, started them by hand, and torqued them down.
Dan LeBlanc
Jon S
Thanks guys!  Pump arrived today.  Everything went smoothly, but the mounting bolt closer to the carburetor was a pain in the neck to get a wrench on - bad angle.  I transferred the AC top to the new one.
Jon
1981 Corvette
2004 Mustang GT
Dan LeBlanc
That bolt is a pain.  Worse on a car with a/c
Dan LeBlanc
