'73 trunk closure
Started by gross707, May 17, 2014, 07:25:04 AM
gross707
I just bought a '73 Eldo and am wondering about the trunk latching mechanism.  It takes a firm hand to close the trunk which then pulls down about 1/2 inch, very slowly and with a minimum of sound/noise.  On my newer (including a '74) Cadillacs this process was accompanied with more sound and more travel.  My question is: is this normal for the '73 models?  Was there a noticeable change in the trunk closing mechanism between 1973 and 1974?
Gerald
Gerald Ross
On a 73 the closure mechanism is a shock like device that rides on a cam on the right trunk hinge.   Its connected to a cable to the latch mechanism.   My guess is over time the shock no longer works line it used to.   I would have to think about the technique I use on mine.  I think I pull the trunk about half way down at any speed I want but then the last have has to be fairly quick but not slammed hard at the end.   If it misses I go back to the half way position and wait for the little shock thing to extend again, you can see it on the right hinge, then try again.
75 for sure had the electric pull down, not sure if 74 was electric or the shock cable thing.   Don't think there are any reproduction shock things available.
Gerald,
The rule to go by in 1960's and later Cadillacs that I use is, would my Grandmother have been happy with how this feature of the Cadillac operates?  She had a 73 Cadillac and the trunk was no trouble to close.  It is not normal and a repair is required.  I have a 1970 Cadillac and plan to add that auto close option and then I will know more how they work.  Catch you later on that.
Gerald,
From what you say your car is just as the factory intended. As TJ says,your trunk closer is a mechanical device that operates using a (noiseless) cable, bell crank and shock adsorber like tension device.  Its main purpose is to pull the trunk lid down tight, ensuring closure and no noise creating wind noise.
gross707
Thanks for all the replies.  Having only '74 (and newer) models' mechanisms for comparison I was concerned that my '73 was not working properly but am now reassured that it is.
Gerald
Gerald Ross
When I first got my 73 20 some years ago I don't remember needing any special technique to close the trunk.   I seem to remember originally it was like the ones with the electric motor that you would close it so it was latched and then over the next 5-10 seconds you could see it pull down the rest of the way.  Guessing after all these years that shock like mechanism just is not working the way it should which is why I now need a special technique.   It seems like the shock thing is compressing too quickly now which I assume is a result of age and the gas or oil pressure in it is just not what it once was.
The cable that connects the shock (actually
an enclosed spring I believe), is prone to rusting being  metal encased and run under the trunk mat.
