1955 Stop Light Switch
Started by D.Yaros, May 18, 2014, 09:49:23 AM
D.Yaros
Anyone happen to have a pic of the stop light switch on a '55 Series 62?  From reading the manuals I gather it sits on the master cylinder.  Is that correct?
Dave Yaros
CLC #25195
55 Coupe de Ville
92 Allante
62 Olds
P W Allen CLC# 20193
Dave,
According to the MPB, the 55 uses the same switch as my 53. It is a mechanical switch located under the floor board. It is not a hydraulic switch mounted on the master cylinder.
Paul
53 Coupe
Twin Turbine
Commodore
If you need to get one, they are available from your local auto parts store. Standard Motor Products offers it under part number SLS40.
D.Yaros
Thanks, but I am not in need.
I have yet to get under the car but need to locate it so that I may route and connect wiring for a 3rd brake light.
Dave Yaros
CLC #25195
55 Coupe de Ville
92 Allante
62 Olds
