1956 A/C Compressor won't switch on
Started by Charlie CLC#18187, May 18, 2014, 08:11:04 PM
Charlie CLC#18187
Is there a low pressure cut-off switch on a '56 a/c system?  I am trying to get the a/c running- it's all there and looks to be in good condition.  I am sure the charge is gone and probably compressor seals leak.  The compressor will run if I jump it directly from battery.  If I switch it on with the regular controls, the idle kicks up, but the compressor won't engage.  Power is not going to the compressor through the black wire.
I won't run the compressor with no charge in it, just want to make sure the circuits are working properly.
Thanks for the help.
Charlie
1956 Coupe de Ville
Jon S
Even with power in black wire, compressor will not kick on unless there is a minimal charge in the system.
Jon
1958 Cadillac Sedan De Ville
1981 Corvette
2004 Mustang GT
J. Gomez
Charlie,
Check the following post; I’ve uploaded a wiring diagram for the A/C that would help you isolate your problem.
http://forums.cadillaclasalleclub.org/index.php?topic=98421.msg266432#msg266432
There is no low pressure switch in the ’56. If you follow the positive path for the compressor solenoid the +12V is from the 3-way switch and the temperature control lever at the control panel.
If you move the temperature control to max/full the lever wiper (Dark Green) would make contact with the Dark Blue contact extending the +12V up to the evaporator (rear unit) freeze thermostat.
The thermostat contacts should be closed under normal condition, this will extend the +12V back to the control panel via the Black. There is a connector at the control panel hardness which the Black wire is connected to the compressor.
I would start with the control panel; check the temperature control lever, moved the lever to the max/full position and verify the contacts they may be broken or corroded.
Good luck..!
J. Gomez
CLC #23082
Charlie CLC#18187
Thanks Jose.  I'll follow your recommendations.  I also checked the thread you started on A5 rebuilding and saw what I could be dealing with.  It is extremely unlikely that mine doesn't need new seals at a minimum, I suppose.
Charlie
1956 Coupe de Ville
