1941 & 42 67 Series Door Sills
Started by harry s, May 20, 2014, 10:18:09 AM
harry s
My '41 67 Series door sills are deteriorated beyond being able to use, especially with new carpeting. According to the MPB these sills are specific to only these two year 67 Series. I have contacted Custom Door Sills in NJ about an aftermarket set. They did one set for these cars 6 or 7 years ago and will reproduce one set for $600 or two for $500 each and probably less if more sets are done. Myself and one other car owner are interested. Anyone else have one of these cars interested?    Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
Doug Houston
Find someone with a 41-61, and check the door dimensions. That's the "B" body that Fisher started in '41. Buick used that "B" body through 198, I believe, as well as Pontiac.I'd need to check on Oldsmobile.
The doors, at least the front ones should be the same ones on the 67 series. You will find that the doors on the 67 series car (at least the front ones) are identical to the 61 series. Fisher body used panels on the 61 and 67 that were identical, at least as far back as the "B" pillar.
38-6019S
38-9039
39-9057B
41-6227D
41-6019SF
41-6229D
41-6267D
56-6267
70-DeV Conv
41-Chev 41-1167
41 Olds 41-3929
