1976 Eldorado sway bar brackets
Started by caddyflo, June 02, 2014, 05:50:54 AM
caddyflo
Hi,
I need to get a pair of new sway bar rubbers and brackets. Finding rubbers is quiet easy, but brackets...
I´ve found some brackets with the GM spare number 406887 on ebay. Does anybody know if these are the correct ones?
Or, are there some other of a third vendor, perhaps. That will fit on a '76?
Florian
Freinsheim, Germany
I have been using some "universal" poly bushings, some with grease fittings.  The
links also use poly washers, with heavier bolts & spacers than stock.  Bruce Roe
caddyflo
#2
Hey Bruce,
thanks for the reply.
As I´m not close to my Cadillac at the moment, could someone tell me what size of the bushings I need? I guess it is 1.25, right?
Thanks!
Florian
