With the help of previous posts, I discovered that the ticking sound behind the glove box in my 1975 Coupe deVille is stripped gears in the climate control module. I removed the glove box and and watched the metal rod at the top move as the temperature dial was changed- it was quiet when it was on 90 but as it was turned down to 60, it started jumping and ticking. I have several related questions- how do I go about fixing this? Would the entire module have to be replaced or can I open it up and replace the gears? is this a big repair for someone with fairly basic skills? Where would I buy a replacement module or replacement gears? The heat appears to work great in the car, its very hot but it only comes out on the floor and it will not come through the dash vents. There is no cold air at all, is this related to the climate control module or is this a separate issue like the air conditioning is not functioning? When I move the switch on the dash to various settings like low or high or defrost, no air is blowing hot or cold, it still comes through onto the floor. Is this another separate issue like a blower motor or is it related to the climate control module? I just recently acquired this car so i am still getting to know it and I have never owned a car with a climate system quite like this one. Thanks a lot!
