The fuel pump in my '57 failed on my way to Back to the Fifities in St Paul. My only choice on short notice was an electric. (I know I should have one any way for easier starting after a long time parked.) NAPA and Autozone can get the '58 pump but not the '57. Hollander says they are different pumps. What is the difference between 1957 and 1958 fuel pumps? Kanter lists the same fuel pump for '54 thru '67 all except '57/'58 Broughams.
The original '57 pump is ONE-YEAR and ONLY Cadillac. The pulsator diaphragm cover is at an angle where the '58 is horizontal. Also, if you put a '58 pump on a '57, the original steel line to the carb won't line up. The screw holes between the pump top and bottom are in a slightly different position than the '57 housing and the line ends up short.This I do know because I tried it...
Hope somebody can post a definitive answer as to "slanted" fuel pump for a 58 or not. I just restored my 58 Series 62 and I needed a rebuilt fuel pump. Vintage Cadillac in Arizona told me I needed the "slanted" fuel pump to be correct. I had to pay an extra core charge because I didn't have the proper "angled" core for the exchange. The core that came off my car was an AC replacement that Vintage Cadillac stated is not factory correct for the car as the diaphragm cover on it was horizontal.
