Phone charger blowing fuse?
Started by Jeff Wilk, July 05, 2014, 02:10:26 PM
Jeff Wilk
Getting ready for drive in our 59 to the GN. I changed out one cigarette lighter socket to a new generic fits right in replacement. Plugged in my car phone charger into the new lighter with nothing attached and the 25amp body Feed blew after about 5 seconds. Any ideas?
Southern New Jersey
SOLD
1958 Cadillac Sixty-Special
1958 Cadillac Sedan
1958 Cadillac Coupe Deville
Coupe Deville
Quote from: Jeff Wilk on July 05, 2014, 02:10:26 PM
Having the same problem as you with my fathers 59. Haven't looked into it yet though.
-Gavin
-Gavin Myers CLC Member #27431
"The 59' Cadillac says more about America than a whole trunk full of history books, It was the American Dream"
Check the polarity of the wires feeding the socket and make sure that the center pin on the charger is supposed to be hot.
Jeff Wilk
Interesting. The original 59 factory lighter recepticle only has one connection point which takes the hot barrel end right onto the center. The new replacement has a center connection AND a spade connector on the body housing of the new recepticle. I only connected the factory harness wire to the center connection as was with the original.
Should the hot be going to the spade connector on the body of the new recepticle?  Or does that spade need to run to a ground?
Southern New Jersey
SOLD
1958 Cadillac Sedan
Coupe Deville
I think the spade connector goes to ground and the center pin is the hot.
Jeff Wilk
Nope. I ran a ground to the new spade connector on the body of the new recepticle and still blows fuse immediately. I cleaned up the other original ligjter socket by the pass side and plugged in the phone charger and it works fine.  This new socket keeps blowing fuses for some reason.
Southern New Jersey
SOLD
1958 Cadillac Sedan
dplotkin
Put your DVM set on continuity and measure between the center connector and the side of the unit. If it conducts, the socket is no good.
Dan
56 Fleetwood Sixty Special (Starlight silver over Dawn Grey)
60 Buick Electra six window
60 Chrysler 300 F Coupe
61 Plymouth Savoy Ram Inducted 413 Superstock
62 Pontiac Bonneville Vista
63 Chevy Impala convertable
63 Ford Galaxie XL fastback
65 Corvette convertable 396
68 Chrysler New Yorker
Do you have any other devices you can try?   I'm wondering if maybe something in the design of that charger that is not compatible with that socket design.   I remember having a device that would do that in one car if I plugged it in 'right side up'.   If I plugged it in 'up side down' it was fine.   The plug looked symmetrical but there must have been something different.
txturbo
Your car is rejecting the modern technology.
D. Roden
1956 Coupe De Ville PINK
1963 Cadillac Sedan De Ville
Julien Abrahams
Hahaha, yes, your car is telling you that it does not want this kind of modern stuff in it. Maybe a silly question, but why not just charge your phone on the pass. side, as you state that this works fine. I think the problem is in the new generic lighter socket.
1954 Cadillac series 62
1967 Cadillac Sedan De Ville HT
1969 Austin Healey Sprite
1979 Opel Kadett
