Looking for KC mechanic
Started by briankm, September 05, 2014, 02:16:53 PM
briankm
I'm looking for somebody in the Kansas City, MO area who may be able to help cure my 1980 Seville of it's bad behavior.
(Hot-start problems, holding idle in gear, stopping dead, etc)
Any suggestions would be great!
Brian Morton
briankm76email addresses not permitted
Glen
I’m not an expert on this year/model but that sounds like an Idle Air Control valve.  If that gets sticky it will cause those problems.
Glen Houlton CLC #727
CLCMRC benefactor #104
Jeff Hansen
Brian,
Contact Steve Christensen in Overland Park.  He is the president of our local region in the Kansas City area.  He will hopefully know of someone who can help you:
Steve Christensen
12321 W. 126th St.
Overland Park, KS 66213-2422
(913) 940-8555 cell
(913) 577-8264 work fax
moc.maetabg@nesnetsirhcs
HTH,
Jeff Hansen
1941 6019S Sixty Special
1942 7533 Imperial Sedan
