Paint for chrome surfaces (center of Brougham wheels)
Started by INTMD8, September 23, 2014, 04:37:02 PM
INTMD8
The center splined hub on a 57/58 Brougham is painted black between the splines.
The company that made my wheels which are a close replica did not paint those areas stating they didn't think the paint would last. (I think they were just being lazy)
Any suggestions on a particular paint to use for this? Is there any type of self etching black paint? Would like to do it in one shot rather than prime/paint if possible as it's such a fine line.
Auto parts stores sell a "black trim" paint that is meant for metal applications like this.  There are many applications from the 50's thru 70's where black paint was applied to alum, st st, and chrome and held up reasonably well.  This paint replicates that process.  It is just a rattle can for $12
Wayne Womble 12210
Adhesion is a problem with chrome and stainless surfaces.  The common practice is to use a very light coat of Zinc Chromate primer and then paint. I use the zinc and a black epoxy primer. Epoxy primers usually have some zinc component, but with the modern formulations, it has been taken out of many of them.
INTMD8
Thanks guys.  Only problem I see with using primer then paint is I'm dealing with a bunch of fine lines and maybe you could see the primer edge under the paint? Maybe a super light coat is how it will need to be done.
If I were placed in your situation, I would not use paint but a black tape. OK, it's not quite an easy job, but it can be done.
INTMD8
Quote from: Roger Zimmermann on September 25, 2014, 02:08:39 AM
Pinstriping tape or something else? I wonder how it would hold up to the heat.
Well...This is a factor I did not take in account. I'm using Scotchcal marking film when I want to simulate black paint on chrome parts. This may resist to hihg temperature as well as paint.
Cadillac Nut
Have you tried Eastwood to see if they sell something that would work?  I know they have black trim paint, I don't know if they've got one that has Zinc Chromate in it.
