Uneven Tail Light Brightness
Started by Tlentz, October 04, 2014, 01:48:44 PM
Tlentz
I finally got my tail lights, brake lights and turn signals working on my 41'.  Does any one have an idea i can look at that would cause the right to be brighter than the left?  Thanks!
Cheers,
Todd Lentz
1941 Cadillac 6319D
1964 Cadillac Sedan DeVille
1950 Chevy Styline Special
5 Crazy Kids
dplotkin
Try a pair of matching bulbs. Before you do that, carefully inspect the sockets, clean the contacts, and inspect the grounds.
Dan
60 Buick Electra six window
60 Chrysler 300 F Coupe
62 Pontiac Bonneville Vista
63 Chevy Impala convertable
63 Ford Galaxie XL fastback
65 Corvette convertable 396
68 Chrysler New Yorker
Bill Ingler #7799
The 1154 bulb used in the 41 tail lamp is a dual filament bulb. One filament is rated at 21 CP and the other at 3 CP. I believe the 3 CP was the tail lamp and the 21 was used as stop or the turn signal. I would check the wiring going into the socket to see if you might have the 21 CP wire hooked into the socket where the 3 CP should be connected. Easy to make a wrong connection especially if you have new wiring and new sockets.   Bill
Jeff Rosansky CLC #28373
Check the terminals and then the grounds.  Squirt some contact cleaner (or even WD40) into the bulb socket.  Then take a piece of scotchbrite and stick it in there then spin it around with a regular screwdriver.  That will clean the socket.  If that doesn't work then clean the grounds.
Jeff Rosansky
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
Tlentz
Thanks guys, I took all of your advice and it looks beautiful!!!
Cheers,
Todd Lentz
1941 Cadillac 6319D
5 Crazy Kids
D.Yaros
Dave Yaros
CLC #25195
55 Coupe de Ville
92 Allante
62 Olds
Tlentz
Not really sure, checked all wiring and wire brushed grounds.   So it was more than likely a ground issue.
Cheers,
Todd Lentz
1941 Cadillac 6319D
5 Crazy Kids
