Question about a 1946 vin
Started by Doug L, October 20, 2014, 01:22:10 AM
Doug L
Is the chassis number and engine number th same on a 1946 commercial chassis?
I have a clear picture of the engine number but not of the chassis number and I am curious if thy should be the same.
Doug Lemon
Smedly
Doug I am not 100% sure but I believe they should match. I have also sent you a p.m. on a different matter.
Sheldon Hay
Sheldon Hay
Jeff Hansen
Doug,
If the engine in your '46 is the original engine, then the engine and frame numbers should match.  Being a series 75, the numbers should be in the range of 3400001 to 3401927.   The number on the frame will be located on the top of the frame rail on the passenger side roughly between the battery and the starter - could be as far back as the firewall or as far forward as the motor mount.  See attached photo.
If your engine number is not in the range listed above, the engine has been replaced at some point in the vehicle's life.
HTH,
Jeff Hansen
1941 6019S Sixty Special
1942 7533 Imperial Sedan
Doug L
Thanks for that guys,
Jeff as you can see in the attached picture the engine number is  3400002.
DLemon
Jeff Hansen
Holy cow, you can't get much earlier in the production run than that! Very cool!!
Jeff Hansen
harry s
Quote
That's exactly what I was going to say. Be nice to know the history.    Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
Doug L
This is not my car,but there is a story (isn't thr always).
I will tell as much a I can after everything has fallen into place.
To be continued...
Doug Lemon
