Attaching fender emblems on 1957 series 62
Started by TBZ_57_Series_62, October 20, 2014, 09:41:13 PM
TBZ_57_Series_62
I am looking to install a couple missing fender script emblems... They have pins, but I'm not sure how they install. Do they just fit the pins into the holes and use adhesive or are there clips or something that hold the pins from behind?
As always I appreciate your knowledge and help.
Ted
They are attached with clips at the rear. I just don't know if such clips are still available as the automotive industry from today (and yesterday) does not use them anymore.
Mike Josephic CLC #3877
They are still available if you find a good auto parts store.  It's a small spring steel type
that pushes onto that pin.  The hole in the clip and the spring action holds it
tightly against the fender.  Take a trim piece with you so you get the correct size.
Also, be careful pressing them on since those pins break easily.
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
Walter Youshock
They sure do break easily!  Anodized aluminum is very fragile.   They weren't designed to be taken off and on.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
Dan LeBlanc
If yiu can't get a spring clip, you could likely get away with using a speed nut.
Dan LeBlanc
David Greenburg
Unless the pins on a '57 are thicker  than those for the trunk letters on my '60, you may have a hard time finding clips that are small enough.  I can't seem to find anything smaller than 1/16" which is too big.
David Greenburg
'60 Eldorado Seville
'61 Fleetwood Sixty Special
jaxops
Try these folks for fasterners! http://www.rjlautofasteners.com/ for a starter anyway.  Good luck.
1979 Lincoln Continental
57eldoking
1957 Eldorado Biarritz #906
1957 Eldorado Biarritz #1020 http://bit.ly/1kTvFlM
1957 Eldorado Seville  #1777 http://bit.ly/1T3Uo1c
1995 Fleetwood Brougham  http://bit.ly/20YwJV4
2010 SRX Performance
1946 Chevy 1/2 ton pickup
1957 Buick Caballero Estate Wagon (x2)
1960 Chevy Apache 10 Stepside
1991 Jeep Grand Wagoneer (x2)
1992 Pontiac Trans Sport GT
Walter Youshock
Rather than permanently mount them with the clips and risk damaging the pins, consider a silicone caulking material.   Once they're clipped on, getting them off is a chore.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
