1960 taillight to body gasket
Started by David Greenburg, October 26, 2014, 04:12:25 AM
David Greenburg
Does anyone know a source for the  taillight housing to body gaskets for a '60?  It's easy to find the taillight lens to housing gaskets, but none of the the usual suspects show the housing to body gaskets. This is not the
David Greenburg
'60 Eldorado Seville
'61 Fleetwood Sixty Special
n2caddies
Hi David
I just saw your post and not sure if you have figured out a solution but what I did on mine as there are no vendors for a tail light housing to body pad. I bought a piece of 1/8 inch thick neoprene rubber from the local hardware store and traced a paper template off the tail light and transferred it to the rubber and cut it out with an exacto  knife. It came out as good as any original I have seen.
Randy George
Randy George CLC# 26143
1959 Series 62 Convertible
1960 Series 62 Convertible
1964 Deville Convertible
2015 SRX
