1914 Starter/generator
Started by rvsls, October 27, 2014, 12:52:37 PM
rvsls
I recently purchased a 1914 Cadillac and am having trouble with the starter/generator.  When I initiate the starting procedure and push the start button, I hear a click but the starter/generator does not motor.  I can turn the input shaft to the generator and it will then start to motor.  Once running, the generator is putting out full amperage (16-18 amps).  It appears that there is not enough amperage coming through the push button circuit to initiate motoring of the starter/generator?  Any ideas?
R Smith
Classic
You might want to try the www.earlycadillac.org forum (a yahoo group).  They focus exclusively on 1903-1914 Cadillacs.  Lots of help there, just like on this forum.
Gene Menne
CLC #474
rvsls
Thanks  Gene!  I have applied for membership in the group.
R Smith
