346 Rear Seal
Started by autoluke, October 27, 2014, 03:07:37 PM
autoluke
Cadillac 346 in my recent purchase leaks like a sieve.
Will the replacement seal be an easy fix, or should i prepare for a major operation ?
Phil Lukens
joeceretti
Lot's of possible places for a leak. Which car do you have.. manual or automatic?
autoluke
Joe
A manual transmission.
Hope to remove the flywheel cover tomorrow for a closer look, and will post the details.
Phil Lukens
I presume thats a rear crankshaft leak?
joeceretti
#4
Typical spots, flywheel cover, oil pan, at the bell housing, heads, at the top of the distributor tower and on the lifter covers... plus if it has a draft tube, most do, you will usually get dripping there
I am still getting a bit of oil occasionally out the top of the distributor tower and one spot on the lifter covers. Will deal with those this winter when I redo my lifters, again.
Removing the inspection cover will give you somewhat of an idea. The rear seal is typically a rope seal and is available from the seal mongers. How clean is the engine? Can you wipe off the oil and get a clearer idea of the source? Is the engine in a car? I assume not. Out of a car is easier to fix. If one seal is bad there is a good chance that multiple places are leaking.
autoluke
I had a good look today, and unfortunately the leak is coming from the rear seal.
I assume that this will require removal of the engine.
Phil Lukens
joeceretti
I believe so. It is practically impossible to get the bell housing off without removing the flywheel first.
TMoore - NTCLC
This can be done with the engine in the car, if you choose to do it that way - you only need to be able to drop the crank just a bit in order to get the seal in.  Search the forum more details, but here are a couple of sample posts - note that many are using the Mercedes part, but the standard rope seal process is the same:
http://forums.cadillaclasalleclub.org/index.php?topic=102132.msg128709#msg128709
http://forums.cadillaclasalleclub.org/index.php?topic=99978.msg135119#msg135119
