41 60 special stromberg
Started by mr41cadillac, November 07, 2014, 10:48:42 AM
mr41cadillac
im having trouble with leaking gas from the big plugs on outside of carb, Stromberg on 412 60 special. what should I use ? I know they measure .75 inside diameter. should I use any kind of sealer ? thanks john
I don't think you are supposed to but I always do. You do need to make sure its a sealer that can withstand oil and fuel and it helps if you have the tie rod tool to tighten them as I find a screwdriver just doesn't do it, its a large slot socket to use with a bar but don't go too heavy
Brett Baird
I have successfully replaced the gasket that should go there with  neoprene o -rings and no sealant
B Baird
17764
'41 Fleetwood 60 S  http://bit.ly/1jwgEWm
'59 Sedan DeVille 6339 "Flat-top"  http://bit.ly/1jwgUF1
