1974-76 Cadillac door stop bushings - where do you get the tubing?
Started by Scot Minesinger, November 28, 2014, 11:06:01 PM
The 74-76 (other years maybe as well?) Cadillac doors do not close well unless a plastic tubing bushing is used on the door stop posts that are horizontal.  I have seen this tubing on numerous nice closing doors on Cadillac SDV and Fleetwoods.  I'm working on a Cadillac that has bad closing doors and no plastic tubing bushings.  I have installed these for other customers, but they always furnished the tubing.  What kind is it and where is it sold?
Scot
Joe,
Thanks went online to buy but they are out of stock.  On of my friends supplied a 6" length of tubing and I cut it and installed.  Someone gave it to him and the story is that they bought tubing for a soda dispensing machine and cut away outer braded casing to use inner liner-seems like a lot to go thru, is there a tubing that someone else has bought that works?
Jeff Moffo
Hi Scott,
My 76 doors close fairly well until you're riding and go over a significant bump. Then they rattle. YIPPEE. Nonetheless, I've seen those strikers on EBay that have the plastic tubing in which you are referring. If you search "1976 Cadillac", they almost always pop up.
Good Luck,
Jeff M
North Jersey
Best of all, it's a Cadillac....
'76 Coupe DeVille - Claret (Sold)
'73 Series 60 Fleetwood (Sold)
'76 Coupe DeVille-Dunbarton Green
Jeff,
Thanks, found them on e-bay and ordered them.  That was easy.  Today I'm replacing the rubber fuel lines on the Talisman, will snap some pictures.
Scot
Jeff Moffo
Did mine on Friday. Was pretty simple. Thanks for your help. I want to do the rear lines when garage is a bit warmer and I can open the door to also get some light. I'd like to see photos of yours though.
Jeff M
North Jersey
