1953 Series 62 Horn Ring Removal
Started by 31caddy, December 12, 2014, 05:17:19 PM
31caddy
I am helping a friend to get his horns working on his 1953 series 62 convertible. There is 12v on the battery terminal of the horn relay, and the horns blow when I ground the S terminal of the horn relay. When the horn ring is held down there is no continuity between the S terminal and ground.
My question is : how do I remove the horn ring/center cap assembly on the steering wheel. This is a VERY nice car and I do not want to damage anything. Thanks.
R. Rowland CLC #28971
1931 Model 355A Sedan (Recently sold)
1931 Model 355A Fleetwood 4535 Convertible Coupe
2005 Cadillac XLR
Bob Schuman
The center button on the steering wheel comes off first. You press the button inward , compressing the spring under it, turn about 45 degrees counterclockwise, and the spring will push it off in your hand. Next, remove the large nut holding the horn ring and steering wheel, and the horn ring will be free.
On my 51, pressing the center button would not free it to be turned, because I was depressing the horn ring with the button. I used two wood popsicle sticks in the gap between the horn ring and top of the steering column. This prevented the horn ring from moving, and the button was easily removed.
Bob Schuman, CLC#254
2023 XT5
31caddy
Bob, Thanks very much for posting! I had tried pressing and turning the center button counterclockwise, but had no luck getting it to come off. I am certain that you are right on target with what was happening and I will try tomorrow to block the ring from moving. I was very concerned that I would break the plastic center cap. Thanks again. Rick.
2005 Cadillac XLR
P W Allen CLC# 20193
The directions Bob gave you is absolutely correct. But this simple job can be absolutely frustrating--- sometimes. The plastic cap has three tabs that fit into a metal ring with a spring in the center. There are three openings in the ring that the tabs fit into. When you push down and turn, you are trying to line up the tabs with the openings in the ring. Problem is, you can't see anything so your doing everything by feel. The clearance between the tabs and the openings in the ring is tight, so they have to be lined up perfectly before the cap will pop off. I've included a photo that shows the three tabs on the plastic cap. Don't worry too much about breaking the cap. It is very rugged as you will see once you get it apart. I've done this job a couple of times. It can take as little as 5 seconds to do, but I've fiddled with it for over a half hour before. Just go slow. You will be only turning the cap about an inch to line up the tabs. Push down firmly while turning. Good Luck! By the way, if by chance the cap does get broken, McVey's has reproduction ones.
Paul
53 Coupe
Twin Turbine
31caddy
Paul, Super-valuable post! Thank you, Rick.  :)
2005 Cadillac XLR
