add oil temperature gauge to 41 60 special
Started by mr41cadillac, January 04, 2015, 09:11:38 AM
mr41cadillac
anyone know where to attach an oil temp. gague to a 41 60 special ? thanks john
Are you asking where on the engine or where in the car?  Or both?    Are you going with electric senders or mechanical?
joeceretti
I thought my post had been deleted until I realized this is a duplicate post.
mr41cadillac
joeceretti
You could put a T adapter in the outlet for the external lifter line and put the sender in there. It would be very hard to see in that location. It comes right off the front end of the main galley so you should get accurate readings.
Like this one... http://goo.gl/kXtEv4
mr41cadillac
yes tee fiting there and gague on under dash
James Landi
hmmmmm... what are acceptable limits on oil temp....what does this reading mean?
joeceretti
Seems to me that the oil should not be much hotter than the water temp. I am not 100% certain if that is logical but I can't understand why it should or could be significantly hotter.
