Interior dash "Grill"
Started by ericdel, January 10, 2015, 05:33:11 PM
ericdel
I am looking for tips on re-painting the black background on my interior dash grill. 1959 6239. I'm assuming I will have to spray the whole thing and then use some sort of fine abrasive to remove the paint from the chrome.  Any tips would be great.  Thanks in advance.
1959 Cadillac 6239
I would not use anything abrasive on chrome, you will loose the shine. I spray first then dampen a rag in paint thinners, wrap it tightly around a block of wood and wipe the surface high spots.
cadillactim
I take a razor blade (like an X-Acto knife) and gently "scrape and chip" the paint off the ridges. The paint will flake off the ridges pretty easy. Then I go back with 00 or 0000 steel wool to remove any residue paint. The fine steel wool also help the shine. This method does not scratch the surface if you take your time.  Personally, I stay away from thinner because you have to use utmost care otherwise it can seep into the low spots and remove paint you don't want removed.
Tim
Tim Groves
BillR. CLC # 29203
eric del,
I had luck with prepping, painting and them immediately after painting, while still wet, I carefully wiped the top ridges with a clean cloth.
I did the same for the three pieces on the rear of my son's '59 of which I've attached a copy of the fuel filler cover.
Good luck.
BillR.
Bill Rodwick
CLC # 29203
Crew Member:  '59 Sedan Deville Six Window
Jon S
Got a very easy way - try your technique on a small piece of trim first.
Make sure the part is clean and no loose paint.
Buy a bottle of Testor's flat black ($1.19) and paint the black parts with a fine model brush.  Before the paint dries, wipe the chrome lines with a soft clean cloth.  Do not wipe where the black should be.  Rubbing horizontally as opposed to vertically should work best.  If you over-wipe you can re-apply to that area and re-wipe.  Results are beautiful!
Jon
1958 Cadillac Sedan De Ville
1981 Corvette
2004 Mustang GT
Tim
[/quote]
I said dampen the rag not soak it. There should never be enough to seep out the rag. Been doing it this way for 40 years but what do I know?  A qualified chrome plater would be horrified at the suggestion of steel wool of any grade on chrome unless its so bad you don't care.
59-in-pieces
Eric,
Good advice from all who offered up their ways.
I have another way that I have used on several Eldo's. - on the dashboard pieces and rear grills.
There are available mat black PAINT pens (not gloss) - very fine and sharp points - from hobby shops, or your local graffiti suppliers.
I simply draw the pen between each groove.
If you get a little shaky, rub off the excess right away - and reapply if needed.
I do have one observation to offer - that unless the pieces you will be painting are "PIT" free, the pits will be instantly noticeable - either on the chrome or polished aluminum pieces.
Have fun,
Steve B.
S. Butcher
Eric DeVirgilis CLC# 8621
#7
In 30 years of use, I have yet to damage the finish of anything with 0000 fine steel wool - on metal/chrome surfaces or glass. Ever.
The problem with the paint brush method is that it is virtually impossible to achieve even coverage and consistency from section to section. "Glopping" is a big problem too.
That said, I'll throw in my recommendations which worked perfectly for the painting of these parts:
1. Take the parts to your local car wash and pressure wash ALL the old paint out. It should come out very easily if all original and no attempt to repaint the parts was ever made.
2. Treat the parts with Prepsol to remove any traces of oils, soaps or anything that may prevent adhesion.
3. CAREFULLY treat the top edges of the metal surfaces NOT to be painted with a THIN coat of Vaseline, using your thumb. Apply in a motion WITH THE GRAIN ONLY.
4. Spray paint the areas WITH THE PIECE FACING THE GROUND. This will help prevent "pooling" of the paint.
5. THOROUGHLY let dry before attempting to remove excess paint - with parts facing DOWNWARD.
6. Carefully wipe the excess paint off. Use fine steel wool - gently - as needed where paint remains on undesired areas.
Following these steps will make the black insert paint look new.
Jon S
Here is a picture of my hubcap which I painted the Cadillac Motor Car Division 10 years ago with the Testor's paint and wipe method. No "glops" whatsoever.
Jon
1981 Corvette
2004 Mustang GT
ericdel
Thank you for all the replies.  I tried the steel wool method and the thinner method and both worked well.  Steve B, you are right.  Any imperfection lit right up.  Thanks again.
Eric
1959 Cadillac 6239
KD
My chrome shop said to use acetone. Use the BLUE paper towels wrapped around a stick, like a paint stir stick, and wipe only one time and one direction , repeat  as needed but only with a clean spot on the towel each time.
It worked like a charm for me on my dash.
The acetone evaporates rapidly so you need to apply the acetone before each time
Ken D CLC#26801
Ken Dennison
1935 Auburn S/C Cabroilet
1929 Ford Closed Cab Pick Up
1960 Austin Healey Sprite
nightshade
I do model railroading and I constantly had to paint my tracks and there is a simple solution:
Coat the chrome with petroleum jelly and then paint. when finished all you have to do is wipe off the Jelly
Paul Pittman
1942 7523 limo
