1936 Cadillac series 60 transmission
Started by bayside, January 19, 2015, 10:21:47 PM
bayside
On the front of the transmission is the sleeve the throw out bearing rides on, inside the sleeve is a groove for an o-ring or felt ? seal.  I tried an o-ring but can't get the sleeve in position because of the resistance of the o-ring.  Thinking maybe a felt seal, without something I think oil would migrate out of the transmission.  Has anyone had one of these apart?
thanks,
Gary
Classic
John Bertolone in Michigan is a '36 LaSalle expert - he's in the directory.  Last I knew he doesn't use email.  So give him a call.  Be prepared for a lengthy conversation.
Gene Menne
CLC #474
