Repairing 1957 Cadillac Convertible rear window frame
Started by Bill Balkie 24172, February 02, 2015, 09:03:03 PM
Bill Balkie 24172
Hello ,
   My Passenger side rear window frame on my Convertible has a few worn spots on the  outside chrome , this has happened over a period of several years . It must of been rubbing on a screw or something and has worn a groove about .030 deep  by 3/8 of an inch wide . I do have the window frame  out of the car .  This window is part of an assembly that has a swivel that is pinned in position at the factory and also a channel for the window regulator  that is riveted to the frame . it also has a channel  revited to the frame  that holds the window weather stripping .  In order the repair and re plate this window channel  I believe the frame has to be totally disassembled . I am reluctant to disassemble the frame in fear that it can not be repaired . Is there any one out there that can recommend someone that has experience  with these frames ? Also does any one know what kind of material these frames are made out of .   They are almost impossible to find . Maybe I should leave it alone but I would really like to get this repaired and re chrome plated .
  Thanks ,
       Bill
Bill Balkie
1970 Coupe DeVille
2009 CTS
57eldoking
We had all our window frames redone by Paul's Chrome in Evans City, PA. I'd reccommended giving them a call.
Paul's Chrome Plating
90 Pattison Street, Evans City, PA 16033, USA
+1 724-538-3367
1957 Eldorado Biarritz #906
1957 Eldorado Biarritz #1020 http://bit.ly/1kTvFlM
1957 Eldorado Seville  #1777 http://bit.ly/1T3Uo1c
1995 Fleetwood Brougham  http://bit.ly/20YwJV4
2010 SRX Performance
1946 Chevy 1/2 ton pickup
1957 Buick Caballero Estate Wagon (x2)
1960 Chevy Apache 10 Stepside
1991 Jeep Grand Wagoneer (x2)
1992 Pontiac Trans Sport GT
Paul Tesone
 Paul's Chrome also did my frames ; but I did send them disassembled . They have made repairs for me prior to chroming on a number of different pieces ,both steel and pot metal. Always a great job.......... Paul Tesone CLC #6876
Bill Balkie 24172
Hello ,
  I called Pauls and he is very knowledgeable about these window frames , He needs 6 to eight weeks . I think I will give him a try .
Thank you very much Paul and EldoKing
   Bill
Bill Balkie
1970 Coupe DeVille
2009 CTS
