Steering column removal?
Started by JoeKarasinski, February 08, 2015, 08:50:11 PM
JoeKarasinski
How does the shift arm come off so the column can fit through the fire wall? There's a nut at the base of it but it only loosens a couple turns. Can't find anything in the service manual I have.
JoeKarasinski
Oh sorry, 1960 6239 4 window 4 dr.
Thanks!
The shift arm itself is like a screw. The nut is there to lock the arm at the correct position. I'm not sure anymore, there must be a flat on that arm to insert an open wrench.
JoeKarasinski
OK, Thanks! that makes sense. I was trying to hold the arm still and turn the nut.
59-in-pieces
Here is a pic which may help.
Note the threads behind the nut going to the end of the shaft which screws into the steering column.
Have Fun,
Steve B.
S. Butcher
