Founded 1958
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Forum Rules
Calendar
Login
Register
CLC Home
Forum Rules
Technical / Authenticity
(Moderators:
Lars Kneller 8246
quadfins
Barry M Wheeler #2189
Bill Hedge CLC 14424
1963 hdramatic transmission question
All Cads
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 1963 hdramatic transmission question (Read 1062 times)
mikecoil
on:
February 16, 2015, 09:54:24 PM »
I have a 1963 convertible coupe with hydramatic (jetaway) transmission. I have just replaced a broken detent roller spring with hopes of getting her back on the road soon. I havent put the pan back on and filled up with fluid yet because I noticed that after hooking back up the linkage for drive selector arm that when I try shifting it moves fine until I hit the dr4 detent and then it wants to spring itself right down into reverse at the bottom of the selector travel. Any input as to why its doing this will be greatly appreciated as I want to get the transmissiion covered back up. Thanks,Mike
Logged
russ austin
Re: 1963 hdramatic transmission question
Reply #1 on:
February 16, 2015, 09:59:17 PM »
Did you follow the shop manual when putting the parts back together?
Logged
R.Austin
mikecoil
Reply #2 on:
February 16, 2015, 11:51:36 PM »
yes .It was a pain but I was able to get the old broken one out and put the new one in without taking servos out or taking anything else apart. Do you think it migt be upside down? The new roller assembly has a bend at the roller. I installed it with the bent down part toward te detents in the transmission
Logged
J. Gomez
CLC Number: 23082
Reply #3 on:
February 17, 2015, 05:53:19 AM »
Mike,
The roller shows to ride on the detent control groves per Fig. 32 ->
http://www.modifiedcadillac.org/documents/Multiple_Years/57-64%20Hydra%20Service/tn/57-64%20Hydra%20Svc-9.jpg.html
Do you feel the same tension by manually moving the lever at the tranny through the full range without the linkage attached?
Logged
J. Gomez
CLC #23082
mikecoil
Reply #4 on:
February 20, 2015, 02:01:55 AM »
Sorry for the delay. Yes when I move it by hand from park through neutral is fine. But as soon as I hit Dr4 it springs right down to reverse at the bottom
Logged
Switzerland
CLC Number: 21015
Name: Roger Zimmermann
Reply #5 on:
February 20, 2015, 02:16:43 AM »
Obviously, you did an error. This system is fool proof as I can remember. Have a look at the shop manual for the installation details. I have to confess that I never assembled that system on a transmission installed in a car; I did that when the transmission is upside down on the bench.
Logged
russ austin
Reply #6 on:
February 20, 2015, 07:58:27 AM »
Take the part off, that you put on, and see if you can duplicate the problem. If not, figure out what you did wrong.
Logged
R.Austin
Print
Pages: [
1
Go Up
« previous
next »
(Moderators:
Lars Kneller 8246
quadfins
Sitemap
1
2
3
4
5
6
7
8
9
10
11
12
13
All Cads
