Fuel Door Spring 1960 Eldorado
Started by Whit, February 26, 2015, 04:09:49 PM
Whit
Might anyone know where to look to find a replacement spring for the fuel door on my 1960 Eldorado? I also need the flat head screws with the spring clip on them that hold the rear 'grill' onto the body and fuel door. Is it a shot in the dark, or is there a 'gittin' place'?
Thanks   Whit
59-in-pieces
Whit,
I though I would post a photo of what the 59 gas door spring looks like.
Maybe it is the same - I don't, but it might get somebody to remember seeing one and help you out.
Have fun,
Steve B.
S. Butcher
Whit
Steve:
Mine is the same, only broken. Thanks for posting the photo...it helps me see how it was positioned. I will try to find a spring that will do the same job.
Thanks again              Whit
59-in-pieces
Whit,
Here is another photo that shows how the other end of the spring is attached to the fuel door itself.
Have fun,
Steve B.
S. Butcher
Ken Perry
I thought I seen somewhere that someone was making those,but I sure can't remember where :(  Seems like if a guy was to make it out of regular wire and then temper it,that  it would work ??? Ken Perry
Cadillac Ken
Whit
Steve...thanks for the additional photo...very helpful.
Ken...would be great to find this guy...or a spring somewhere. Not having a torsion spring like that, it's hard to know how the door is held closed and then stays open when pulled open. The direction of the winding and whether or not its a 90 degree or a 180 degree torsion spring may be key. I assume that it 'snaps' over center to remain open and then is under compression when closed. Hard to figure out without having the spring.
Thanks to all for the input.
Whit
Jeff Wilk
Try here. They have them. Good luck.
www.cprforyourcar.com
Southern New Jersey
SOLD
1958 Cadillac Sixty-Special
1958 Cadillac Sedan
1958 Cadillac Coupe Deville
Whit
J Wilk:
I checked their web site and they do have them. Thank you for the lead...I will call them tomorrow morning.
Regards   Whit
