1956 master cylinder rebuilding?
Started by smilasm, March 09, 2015, 04:13:40 AM
smilasm
Hello,
I am rebuilding MC and booster on my 56 DeVille. What kind of tool you are using to clean MC rubber cup and seal place? I used sand paper, but it still looks not so shiny.
Marius
Marius Smilas
1956 Sedan DeVille  http://bit.ly/1hsWhri
 :what grade sand paper, was it rust pitted?
smilasm
No rust,just a little corrosion.2000-2500 sand paper
Marius Smilas
J. Gomez
Marius,
From the picture of the M/C it looks to be a Bendix type correct?
Just be looking at the surface on the inner and outer liners they both looked in good shape. As long as the fluid seal inside and the two outer seals fit is tight once the plunger is in place you should fine.
Sanding them with 150-200 with light pressure should be fine just to removed the surface rust. You do not want to go over board at these two areas and make them shinning were the seals are place.
Good luck..!
J. Gomez
CLC #23082
smilasm
Marius Smilas
