Converting air conditioning on 1978 Eldorado
Started by T2207nb, March 24, 2015, 09:42:34 PM
T2207nb
I am considering buying a 1978 Eldorado.  The a/c has not been converted.  How big a deal is to make the conversion?
waterzap
Why do you want to convert it? You can still get R12   It cools well
Leesburg, AL
I have a 76 with 134A in it and it works well.
I also have a 70 with R-12 that works much better.
I would advise R-12.  It's sold on craig's list but you need an older shop to vacuum your system and recharge it.
Although if you are just a bit low you can top it off possibly?
T2207nb
Thanks.  I guess I thought I had to convert it to be compliant with regulations but if that's not the case then it makes things simpler.  Hopefully the system just needs a recharge.  I will be personally viewing the car for the first time on Saturday
Nels Bjorkman
